I have a baxi bermuda fire and back boiler which is getting very noisy when i put the central heating on.
I get the kettling sound i have heard mentioned on the forum.
Anyway i bought some sentinel x100 and 200 and understood you could put it in the small tank in the loft( not the main clean water one)
There was a bit of crap in the small tank so i gave it a good clean and tied up the ballcock to prevent refilling.
I then added both bottles of sentinel then started the ch up and untied the ballcock to let the tank fill again.
Have i done this correctly or should i have drained off some water from the system ie the rads?
How often will the water from the header tank get into the system, does it circulate or will it just sit in there.
When i emptied the tank and put the sentinel in some did drain away into the system but not all of it.
