Hi guys,
My CU (Split - RCD protected) is in my garage which has an electric door, so when the main CU trips I can't open the door electronically which is a pain as I need to get in the garage to reset the trip!
So what I want is a separate 1 gang CU that takes it supply direct from the incoming supply and is totally separate from the main CU, which will then be only used to power the garage door. So this means when the house CU trips, the garage door will still be powered on the separate supply.
Now can I just open up my main CU, find the incoming supply cables and run a new cable from them to supply a new separate new CU box? My main CU has a main switch in the outside box so I can safely isolate the main CU supply side while working on it.
Any advice, tips etc? I'd like to do the work as much as I can as i've done plenty of electrical work before and have multimeters etc.
