I'm considering an extension on the side of my two-bedroom end-of-terrace house. The current heating system is a Baxi Bermuda backboiler serving five radiators (two upstairs, three down).
I had an opportunity to replace it with a modern boiler but my best quote of £2400 meant that it made no financial sense when I considered how little I paid for gas already, and what % saving I might achieve with a new boiler.
The extension would add three or four rooms and I'm not sure plugging them in to the existing heating system would be sensible, as it may not be able to serve it very well. Also, there's no obvious way to plumb through to where the extension would be, as all the radiators and other stuff are on the opposite side of the house, if that makes sense. There'd be a fair bit of new pipework involved and I'm not sure where the best place would be to hook it up.
The extension will include a utility room which will then house the gas meter (currently on the outside side wall of the house, so there is certainly gas available. No water nearby, but this could be brought through somehow.
My idea is that it may be better to have a new and separate heating system in the extension, with its own boiler, installed as the extension goes up. What do you think of this - does it make any sense?
The alternative is to indeed put a new boiler in the extension area, but then hook that up to the rest of the house as well.
1) Try to run the extension on existing boiler.
2) Have a separate boiler system, keep old one in old part of house.
3) Install a new boiler system for both.
Any thoughts?
Thanks,
Any thoughts?
Thanks,
