- Joined
- 4 Feb 2008
- Messages
- 2
- Reaction score
- 0
- Country
Newbie to the forum, please treat me gently....
I have just taken delivery of a new bath with separate taps and spout from Bathstore, and I need some advice on the best way to connect them.
The taps (basically 2 individual valves) have 3/4 inch connections but the spout is just a single 1/2 inch. The original bath had 22mm pipes so is it worthwhile using 22mm to the new valves? (15mm would be much easier and cheaper to run, as I have moved the bath)
Also, given that the spout will be on the opposite wall to the valves, mounted on the front edge of the bath, would combining the feeds closer to the spout make any difference to the flow rate?
The bath is fed from hot and cold water tanks.
Thanks in advance,
John
Thanks in advance,
John
