So looking for guidance and expearience of others who have done similar things.
We are renovating a mid terrace victorian property got to the bathroom/kitchen stage and having all lead water pipes which looked like they are originals decided we may as well separate from the shared supply while replacing all our pipes. Called out wessex water who were great and said all their work they would do for free and all I had to do was a small trench at the front to bring it in and dig down to the shared supply ready to be cut off from the tee which they said ran from the stoptap directly infront of my door to my kitchen and then fed one neighbour.
Now the fun started breaking the kitchen concrete slab (suspended floors everywhere else) I hit a lead water pipe in the top 50mm of screed no where near where it came out of the floor after the water was turned off further excavation revealed it ran accross my kitchen coming from one neighbour to me with me coming off for the kitchen and another for the old wc and on to the next neighbour.
So after a mad panic cutting out a section of lead and replacing with mdpe, numerous trips to try and appease increasingly irate immediate neighbours and finding out we cut water to it seems half our street its atleast temporarily fixed and dry so we can press on with our new supply.
Once I have my water sorted im going to have to make a permanent fix to the shared supply although I wont be on it any more. Now it runs from under my party wall across the kitchen no more than 50mm down to the other wall where it comes up slightly above the ground and tees into the wall where I assume it dives down under our patio to next door.
Has anyone had any luck with a water company moving a shared supply?
If I do have to sort this myself as Im pretty sure I will do you think I should go through the slab under the screed and bury it deeper or could I put a lid over the new pipe?
Im gonna have to take a chunk of the wall out to attach a fitting to the lead and once im off the shared its just gonna be a straight lengh of MDPE but how deep I really dont want to break underneath the pipe,
Thank you for taking the time to read all of that.
Matt
A picture helps so here you go please ignore the tap in the middle that needs to come out.
Matt
