Can anyone explain this system - I am at a loss to understand it. Seems to be a one off?
Bought house 12 months ago, had survey before, surveyor was not able to say what type of system it was - had never seen one before! Sooo, take a breath and buy anyway.
The plans that I recieved with deeds show unit marked and notated as septic tank. To describe house, built 1920's, walls 400 - 450 thick and solid red brick, situated away from village although it has 5 other places nearby.
The unit described as septic tank has appearance of 2 inspection chambers, 1 metre square and approx metre deep, side by side each with it's own cover and a grill on top of one. No vent other than this one grill.
The first chamber has inlet at bottom leading into gully which flows through to next chamber. This first chamber has rainwater from adj. 2 properties and kitchen waste from one. No solids in via this inlet.
Second chamber has all waste from our property flowing in via inlet at bottom of chamber, includes solids.
My first look inside both chambers was about 6 months after moving in and system obviously in use. However, bottom of both chambers were clean of all waste, having small amount of water laying inside.
My second look inside chambers (last week) saw solids in the first chamber with depth of grey water some 150 - 200mm deep.
It seems as though solids from our waste inlet flow back into first chamber where they sit and degrade.
Some 30 metres from these chambers is another inspection chamber which has clear water flowing into it from the unit descibed as septic tank. This then just disappears under the adj. road and goes.........? no idea.
stephan
stephan
