- Joined
- 6 Jan 2004
- Messages
- 15
- Reaction score
- 0
- Country
Hi. I moved into my house about a year ago and have finally got round to sorting the garden out. The garden is relatively low in comparison to the large green out the back (and to my neighbours gardens). It also lays incredibly wet/waterlogged during the winter. I spoke to my neighbour about it and she seems to think there use to be a pond there many years ago (?). Now the garden is all clay (very dense), and I took it upon myself (as the grass was a mess) to remove the current turf - which i have done. The plan was to then lay about 15 tonnes of top soil (to raise the levels) and to create a series of pipes off to a soak away and then turf. I dug out a large soak away (aprox 4ft x 4ft) and filled with rubble, however the following day we had terrential rain all day. Subsequently the unturfed lawn was between 2-6 inches deep in water, and the soak away was fall! The garden was one large shallow pond! Five days later and there is still large amounts of sitting water and the area is a mud/sludge bath. I've almost come to reason that the soak away is just simply not suffice and I realise that if I want the sort the garden out properly then I somehow need to take the water away. My only other suggestion, which i hope someone could comment upon (good or bad) is to run a series of drainage pipes into one main pipe and then run that into my man-hole cover into the system (by the house). Now this would certainly take the water and hopefully the drainage problems away from my garden, but I dont know the legalities of this. I know I could do this quite easily but I dont know whether I should be doing this or not. Does anyone know of any reason(s) why I cannot do this, or suggest any other ways of sorting out this dreadful problem.
Yours in despair
Chris
Yours in despair
Chris
