Hello,
Is it ok to connect the bonding conductor of the incoming gas
supply directly into the cu block where all of the other circuits are
terminated.
As the main earthing terminal fixed to the service head has room for the
main earth only. Also the incoming water supply is at the rear of the
house and I was wondering if you can bond the pipe into the nearest
circuit earth terminal rather than running a cable back to the cu.
Thanks.
terminated.
Thanks.
