- Joined
- 14 Oct 2004
- Messages
- 30
- Reaction score
- 0
- Country
Hi all, Im moving a towel rail in the bath room, and also running another radiator off it. It looks like the towel rail was fitted after the C/H system because the pipes come from the boiler upto the tank and they (who ever THEY are), fitted this rail to these pipes. The problem i have is the pipes drop down from where there fitted to the main system, so when i drain the water im still going to have water in this part. is it worth fitting service valves to this so i can just drain this part down if i need. The new radiator is lower than the towel rail so i can drain it off from there. Are you able to fit service valves here? (in the C/H)? Or is it not worth the bother.
Thanx.
Thanx.
