(This is a multipoint instantaneous water heater!)
A few years back a registered gas installer replaced the diaphragm because the heater stopped kicking in, so no hot water. It had a big hole in it. He did a general service (I think). I mentioned that it also seemed odd that we'd always needed to run the hot tap near full flow for the water to get hot and that was still the same. He didn't think that was a problem.
I've just had the same company attend because since a couple of weeks ago the water temperature became much hotter, and after turning the temperature control dial down it wasn't altering the temperature, whereas it used to.
This engineer said initially something about the diaphragm but that "we don't change them" because you can't re-seal the assembly. I told him they'd done it before but he insisted, and said he done it himself before but you can't get them to seal.
But he also said it shouldn't require running the tap so fast to turn the heater on and that the gas section would need replacing too and that might not be worth it; probably better to replace the whole appliance if we can't live with the hot water as it is. He said otherwise no problem to leave it be, as it's not dangerous.
Although he did seem a bit 'vague' about exactly what was wrong. He was a lot younger than the previous engineer. FWIW, they all work for the company according to the website i.e. no contractors.
We were charged £102 for a full service, but I'm pretty sure he didn't do anything other than take the casing off look around and vacuum around inside a lot. What *should* a service mean?
And who's right about replacing diaphragms?
Could the diaphragm seal have always been the problem with the flow rate? It was always like that though.
At the moment I'm leaving it.
