Hi Guys
I have this thermostatic mixer tap/shower. The shower (central tap) has a single control for flow and temperature. It has started getting stiff and there is now a water hammer "clunk" when turning it on.
Any suggestions on cleaning? Should I remove the top in the same way as a normal tap, and then try and clean/descale the valve?
Do you recognise the tap and know where I can get a service kit or replacement valve if necessary?
bsr
View media item 75602
bsr
