Can you help please my washer starts of normally but will not turn properly, it gets about fifteen mins into the cycle then it will not carry on. Thanks
Hi had problems with washers in the past not going full cycle, your problem could be the brushes in the motor worn, my problems always turned out to be some component gone on the circuit board
