Hi everyone,
Question 1:
I'm looking at replacing the servis antidisturbance filter. However, my model looks different to the model found in the replacement part websites/ebay. The HF rating 25/100/21 is the same and all the sites state that it will fit my M6011.
However, the pin placement isn't the same. The pin placement will be easy to work out. Can anyone see any problems with this?
Question 2:
I'm considering replacing the part because the plastic holders on my filter cracked. I decided to research non conductive glue. I remember from PCB restoration, to look for conductive/non conductive types and selected superglue since my aim was to glue the plastic panel and it is non-conductive. However, some glue dribbled down, round and through the left side of the anti-disturbance filter, with a little part ending up on the copper coil and the yellow left terminal leading into the caps.
Now, from my experiences, the terminals happily survived the bonding process (which is often the worry), the machine works without issue. I further did research and from what I gather, the super glue will just act as an insulator.
Should there be anything to worry about? I've attached the washing machine up to a circuit breaker just in case. I can't see any problems with this but please let me know if I am wrong.
http://www.imagebam.com/image/bc36da82602098
Thanks,
Andrew
Question 1:
Question 2:
Thanks,
Andrew
