Hi, I have had my servis washer dryer for about 5 years. I had it on a 40 degree wash which i stopped manually mid-cycle to change to a quick wash.
It has not worked since! I have tried setting it off to reprogram with no joy.
All the lights come on ok and correspond to the correct cycle.
I never use the dryer part as it kept over heating when i first bought it, and the engineer said it was common to take 3 hours to dry a load!
I drained the water manually and the filter is not blocked.
The drum rotates freely too.
I took the top off and tried to press the small red reset button in case it has over-heated but nothing seems to work...
I don't want to waste money getting it repaired if it is time to get a new one...
Any advice greatly recieved
