Servis M6030S Leaking
26 Feb 2007
Sussex
Hello! I had a Servis guy out to see the washing machine as it's only 9mnths old. He found a coin popped out of the plastic drum. While it wasn't covered under warranty he told me how to fix it which I did. Since then though, it seems to be leaking out of two different areas, the back and the front. No leaks in the door seal and I can't find the one at the back. I can tell water is leaking where the cement ring goes around the drum because it's wet after the cycle.
Your advice would be greatly appreciated.
Sincerely,
Katie : )
