hmmm...drum spins fine when it has some momemtum, but when idleing it finds it difficult to do a whole revolution....when unloaded is fine...so, I took out the motor to check brushes etc, only to find it is completely sealed..?? How or even can, you change /check the brushes on these motors...Mr Thickie here has put it back in, without taking any serial numbers/model type, but the machine is a cheap Servis Automatic 1000 ... I tightened the belt, but that made no difference...
Also, what if any, damage will having the incoming HOT water feed turned OFF, to this or any machine..I didnt think it mattered much, but I have been told that it should be turned on..?? ..surely having the cold feed only is fine, if you dont mind the cost of electrically heating the water each time..
Any help appreciated...
Cheers, Mark
Cheers, Mark
