Hi, can you help?
What setting should my Biasi boiler be on to work with the wired, programmable thermostat? The boiler is correctly connected to the thermostat, and was working. (Going on and off according to the thermostat settings.)
Since a powercut the boiler doesn't fire up when the thermostat tells it to. (I can get the boiler to stay permanently on, and the hot water is fine, so the boiler is fine.)
I'm struggling to understand the manual. What setting should the boilers digital display be on so that it comes on and off with the thermostat?
Many many thanks for any help you can give with this. Cathy
