I have a frost stat fitted on the external wall next to my boiler in the loft. I also have a pipe stat on the return set at 10 degrees.
What I am not clear on is the setting on the frost stat. When I take the cover off I can see the 5 degree arrow pointing straight upwards. I understand that I can turn the stat down to 3 degrees by turning the dial clockwise. However the dial appears to be able to turn a little further than where I guess 3 degrees should be. Should I simply turn the dial as far as it can go clockwise safe in the belief that it is now set at 3 degrees? The reason I want to change the setting is the boiler keeps coming on more often than I think it should. Another thermometer indicates the air temperature is around 7 degrees when the boiler comes on. Is the frost stat faulty or is it just that the setting is unclear?
