I'm going to slate a new roof for a shed I've built. It has a lean to roof and the slates I am using are 500mm long and 250mm wide. The holes are pre drilled 190mm down from the top.
QUESTION? - Is it correct or incorrect to have the top edge of the slate resting on the next batten that slate above nails to?
Should the eaves course rest on a tilt fillet instead of the facia?
