- Joined
- 7 Sep 2022
- Messages
- 2,980
- Reaction score
- 784
- Country
So, of the few resources I've found around the web about laying out a slate roof, some discuss battening out to the ridge, but the advice doesn't make sense to me:
1) Full slate on the eaves, 50mm ish overhang to the gutter
2) Set the first batten so the nail holes are central
3) Next batten up (ignore the short course at the eaves for now) positioned so the top of the slate is just less than central (so the overlapping slate's nail holes are central)
I'm ok with that, but then:
4) measure the batten gauge
5) measure to where the top batten will go
6) divide the distance by the gauge
7) round up
8) divide the distance by the rounded up value; that's your actual gauge
Er, but say if the gauge is 200mm, and the distance to the ridge is 2040mm that gives 10.2 courses, round up to 11, 2040/11 is 185mm, but that's dropped 15mm off the gauge, which means the nails of the slate on row 3 probably end up punching through the slate on row 2..
So am I right in thinking that for pre-holed or reclaimed slates, your batten gauge is set/dictated by the holes; if you want a wildly different gauge you re-hole the slates, or you put up with the top course landing wherever it lands?
7) round up
