How long will rapid set flexible adhesive take to set when laying travertine ontop of ditra.
I have ufh below the ditra which i won't turn on for 2 weeks after grouting.
Its usually somewhere between 40 mins and 3 hours. the ditra will slow it down a little but not much as its a chemical set. room temperature is the main thing.
BTW if its light trav, make sure you get a white rapid set, not grey.
