Hello All
I purchased and put up a Pyronix KX15DT.
its setup in dual tech mode and set to both to cause an alarm.
it says it should be installed upto 2.4 meters but i have installed it at 2.6 as my ceiling is higher.
Now there are three LED states.
Green for PIR
Orange for Microwave and
Blue for Alarm which i suppose means both have been activated
so i have set the microwave quite high and this flashes orange when i walk anywhere in the room
to get a blue or green i have to walk all around the room before it will create an alarm state.
I have set it as both to create an alarm to cause less false alarms
its picking up the entire room on Microwave but PIR only near the alarm on the left where i can walk.
Am i missing something
i tried changing the sensitivity from Auto to High and this did not fix the problem
would the height affect the PIR sensor.
thanks
Green for PIR
thanks
