Setting up Worcester Wave
30 Jan 2006
Lancashire
The pre-set time schedule appears to only set back the temperature about 5 degrees in an off period and down to 10 degrees overnight. Our controller is in a community building with very differing daily heating requirements, some only for short periods. With the old system, programmer and stat, when it was off it was off. Presumably with the Wave if the temperature drops below the set back, the heating would come back on. Accordingly I have set the set back (off) temperature to 10 degrees and the overnight(sleep) to 6 degrees. Have I not understood things and therefore messed up? no mention is made of varying the temperatures on the Wave you tube vid.
TIA
A4L
