Apologies if this is the wrong section as I couldn't find a relevant section to post this. The water in my house has a really high amount of limescale. My toilet pans where the water comes out from the cistern through the pan has a lot of limescale vertically. No matter how much scrub it and I used domestos limescale remover etc but nothing works. Only way is to use a blade a scrape it off but that leaves scratches on the pan. I feel like if I could keep the area soaked in water then I could use kettle descaler but kettle descaler needs the limescale to be in water for a bit. So unless I can plug the pan and fill it with water then that won't work.
Can anyone suggest anything that might help?
