I have a run from the house down to the septic tank which is around 60m long.
At the start of the run there is no liquid. By the time it enters the tanks, there is a steady stream of water which is generally clear and looks like you've left a hose on.
The pipe is 110mm plastic.
I've had it camera'd and it's not got a junction in it, has some "bellying" in it where it's full of water and clearly not a straight run (read: the ground has moved and it's moved with it).
My thinking, and the drainage guy, is that there are several small cracks in it which are allowing ground water to get in.
This makes sense as:
1. If I dig a 4ft hole, it turns into a well. We live on a moor.
2. In the manhole at the end, there is a small crack and it allows a steady drip of rain water in.
The drainage guy wants £11k to sleeve / patch it.
To me, if feels like perhaps he's pricing himself out of the job and not interested.
Question:
1. is my conclusion on ground water correct
2. Is the proposed solution the best one
3. Does the price seem corrct for it.
thanks.
Question:
thanks.
