Hi all.
I've a drain access at the end of my garden and T****s water have had to clear a blockage recently. This has happened a number of times over the past couple of years and these guys were the second lot to advise that next doors' sewage pipe is draining into mine and that it shouldn't). They also did a dye test to confirm this.
The neighbour is a good enough guy whom I get on with and is aware but isn't saying straight up that it was his doing, which in all likely hood is the case. I won't go into anything here as i'm not looking start an 'are you sure' debate but working on the premise that it is his works which has lead to the joining of his pipe to mine i'm looking for some advice on what to do to resolve this while keeping things as amicable as is possible.
Thanks in advice
Johnscales
Thanks in advice
Johnscales
