Hello, I am pretty new to drainage and hoping the experts on here could help us.
We have a house that is lower than the public sewer, we have ordered a pumping station to move the sewage to the main sewer.
At the moment there is an old fossa that just leaks into the soil around the tank, it has also a cracked concrete top and no access cover hence why we are going down the pumping to main sewer route.
We have a large buildings that we are thinking of converting later on so would like to utilise the pumping station for both buildings, to do this I would need to run a 110mm soil pipe or larger if you think I should. This pipe would serve two toilets and two bathrooms plus a kitchen.
My question is what is the maximum length I can run the main pipe from the house to the pumping station, the distance I'm thinking is around 20meters. I can create a fall but unsure what size pipe to use and what fall that size pipe should be.
Many thanks for any help with this.
Wayne
Wayne
