Hi
I am building a conservatory and will put in footings for the wall at 1 metre, now a sewer pipe clips through the corner of the footings so it goes through 2 sides, it is also quite near the bottom of the footing. My question is, how do I bridge the pipe with it being so near the bottom of the footing ( if it was near the top I would lay the concrete let it dry then place the lintel on top) with it close to the bottom I can't lay a bit of concrete, let it dry, put the lintel on then fill in the rest?? or can I???
