Shallow plasterboad boxes?
16 Jan 2009
Avon
I plan to add a double socket to a wall which is plasterboard with a gap behind it and then concrete block. I have ~22mm from the face of the block to the surface of the plasterboard. Are there any shallow dry wall / plasterboard sockets out there or will it have to be a metal box fixed to the block? I can see shallow metal boxes but not plasterboad boxes.
Thanks!
OK, so assuming I chase out some of the concrete block, should I still use a plasterboard box? I assume I should use conduit to take the cables behind the plasterboard and down below the floor?
Thanks!
no use metal.. "plasterboard boxes" are for use in stud walls where there is no solid surface to fix a box to..
don't need to bother with conduit..
must use gromets in the holes..
socket must be RCD protected ( can be an RCD socket or fed from RCD protected circuit )
new cable must be RCD protected or installed in earthed metalic conduit or trunking, or wired in a suitable cable such as Ali-Tube..
OK, the plasterboard is currently off the wall after a water leak soaked it. It's being replaced by the freeholder's contractor and I spied the opportunity to get another socket in. How should I go about this? I'm thinking:
1. Chase hole ready for box
2. Put plastic conduit in place from position of socket to underneath floor, just to aid feeding wires later
3. Contractor puts up plasterboard (not dabbing where the box will go!)
4. Cut hole in plasterboard and fit box
5. Get electrician to wire up
6. Decorate
Does this sound sensible? I've no experience in such things but fancy taking advantage of the opportunity given by the plasterboard being absent.
Edit: Circuit is RCD protected.
ok, STOP right there...
is there a possibility ( no matter how small ) of there being another leak there?
where is this socket to be located ( kitchen? )
6. Decorate
1, 4 ( fit box part of it ), 2, 3 ( contractor will cut box out.. ) 5, 6..
if you don't need the socket just yet, fit a blanking plate over it..
do you really need another socket there?
The leak was related to the roof, I currently have a few blocks missing as part of the investigation and scaffold outside. I won't be letting the blocks (and plasterboard) be replaced until the leak is most definitely fixed! It's in my bedroom which is currently slightly draughty due to the missing blocks...
6. Decorate
Is it not difficult to position the box ready to be flush with the plasterboard when the plasterboard isn't there?
This is why I'm working it out in advance of doing it. If it's too much trouble then I'll leave it as it is. On the other hand I need to do these things sometime so I might as well learn now!
It doesn't have to be perfectly flush. Just make sure it isn't going to be sticking out of the wall. If it ends up set back into the wall a bit it will not matter.
