- Joined
- 1 Apr 2004
- Messages
- 4
- Reaction score
- 0
- Country
I have a shallow well, I know that part. Just purchased the house in December. The well is across the road (dirt road) and down hill from the house. The pump was working till the floor guy decided to leave the water "dripping" one cold night when no one was here yet. We ended up with no water by the next day and when primed, the water was brown for a while. After that, the pump would pump water and fill the holding tank (blatterless)but it just won't hold it's prime for longer than 45 minutes. When I remove the pressure guage to reprime, if the pump has not been running, ie: first thing in the morning before anyone has used the water, the pump is full of water. There is a check valve before the pump, in the basement. It takes about 1/2 gallon of water to prime and we're up and running for the day as long as I set the timer and run the water till the pump turnes on every 45 minutes. Your thoughts?
