I want to radius the four corners of a 300mm x 30mm piece of hardwood. The radiuses will be 1”. I was going to rout these but I am not really sure of the best way to do this. On two of the corners I will be cutting against the grain and I am worried about chipping the wood, is it best to cut these from the other side? Is the best method to use a template for the router? It would be great if I could run the router all round the template but this will mean cutting against the grain at two corners. If I turn the work over for these, I am likely to end up with steps along the straight sections due to slight differences in template positioning for each side. Any advice welcomed.
