Sharing water supply for fridge dispenser/washing machine
20 Nov 2021
Do I need a non return valve to prevent back flow from the washing machine hose, or can I just use a standard Y piece to share the water supply?
Many thanks
Many thanks
If you mean the cold water mains, then you can just share it, there is no backflow.
Standard is fine, but you may want to consider a check valve on the wm hose as the fridge is of course for drinking water.
Thank you. This is what I thought. Some people were saying it’s fine to use a standard y piece but I was concerned that water from the washing machine hose could potentially contaminate the drinking water. But not having any idea about plumbing I wasn’t sure if my logic was right
