Sharp R959SLMAA combination oven - Ghostly turntable
11 Jul 2017
Everything works perfectly - microwave, grill and oven but I found it quietly turning by itself this morning, door closed, stone cold. I think the light was on too. If you open the door it stops as normal then caries on turning when you close the door. The display works normally when you select the cooking method. Once cooking is completed it switches off as it should but it will be found later to be doing its quiet ghostly turning again!
Any guesses anyone? Here are some pictures of the inside from a year ago (the last time it went wrong) if it helps to see how it's constructed. Thanks!
