Hi all,
Not sure why this happened since the lighting re-wire (missing earth) and once this was done, the old socket seemed to be tripping the circuit so it was presumably just switched off (was an old one with an on/off switch).
I've recently removed this switch and put in a new one but doesn't work! The cable does make my voltage tester beep so I assume this means the cable hasn't been disconnected (and judging from the job the electricians did, I very much doubt they went back into the loft and removed wiring).
I've tested the socket by wiring up to a normal socket and works ok so wondering if the light circuit can power the socket (testing it using a toothbrush charger).
Any advice would be appreciated!
