Shed base advise please.
14 Nov 2005
Good evening all. I've got a job of installing electrics to a 5mx4m wooden building. This is currently sat on a 6mx8m concrete slab. You can see where the wood is damp due to just sitting on this slab with no dampproofing or shedbase. I'm concerned that all my work is going to wasted unless this structure is lifted and a proper shed base is built. What advise can I give to persuade owner to do something about this so it doesn't bite him later please. Tia Jack
You've been asked to wire it up do that, you could lose the job by introducing further problems you've not bring asked about.
Do your work get paid and give them advice about the shed when you've finished. Nothing wrong with that ........ your not wrong in your thinking however you could be over complicating it to your customer and they might think your trying tk gain extra work. Your not responsible for the work of others.
Thanks but it's for a local scout group so don't want them to go through loads of work and expense and it rots away ina few years.
Stop surface water flowing under the shed and provide air flow.
If the timbers are not tanalised, then they will rot quickly regardless.
Yes you are right. The shed needs isolating from the concrete
as its a bigger slab, rainwater will run across and pool in any low areas.
the shed needs raising and supporting on something rot proof -even some plastic spacers 12mm thick would do -or maybe given the base is 6m x 8m -it could easily be out of level by 20mm.
I set my cabin floor joists on top of upvc trims and glazing shims where needed to pack up.
Im not a fan of using a continuous DPC like one used for brickwork -I think it risks condensation.
Thanks for the replies, I'll pass on to the Scout Group.
