Two years ago I had a consumer unit fitted in the shed to supply a LED bulk head light and double socket. In the consumer unit I have three switches: one for socket, one for light and the main switch. I wanted to change the light and when wiring it up (with all power off of course) I made a mistake and when I switched the power back on and flicked the light switch some or all switches in the CU tripped (stupidly I did not pay particular attention to which ones or if all of them tripped). I rewired and wanted to test it all again, but now I had no power to the socket or the light (even though I did not change anything in the socket set up). I found that an MCB on the consumer unit in the house had tripped and I reset it hoping that was the solution, but I still had no power. I was then worried that the MCB broke/had blown and I replaced it today, but still no power. What else can I try? Could both circuit breakers in the shed have broken/blown? Is it worth a try changing those?
Any help/advice would be great! Thanks in advance.
