Hi all, I'm building a large shed/workshop/man cave in my back garden (I only moved in over winter). My garden slopes down on a slight incline away from the house (which is good in my opinion), but 3/4 down it raised back up so that in the wet winter it flooded in the middle (Sussex clay ). Problem is, this is where I want to site my shed.
During these cold wet months I excavated out the last 1/4 of the garden so that the incline went all the way to the back of the garden. I then dug a pit and sunk an old rainwater barrel so that the opening was just below the surface. I popped in a water pump with the outlet running back up the garden and along the side fence where there is a manhole that collects wastewater from my house, and my neighbours each side (yes, I saw some nasty things while doing this ).
Hey presto, dryish garden for the rest of the winter! My flooded neighbours looked on enviously
Fast forward to now, I have put the concrete in and laid the blocks in a block-pier foundation (a square grid of 9 piers) on which will rest bearers and joists etc. However, before I do that, I need to do something more permanent with the drainage. My plan is to bury the 40mm waste pipe under the shed within a bedded 110mm drainage pipe serving as protective tunnel buried in a trench under the shed, taking the water from the pump (located behind future shed) and piping it under and out the front where I will then be able to take it (underground still) to the sewer.
Here's a bird's eye plan:
Here's a profile view:
My questions to you:
Trench running between block piers:
Picture of the barrel (pump removed):
Hope you can help!!!
- Am I doing anything wrong here, or have I overlooked anything?
- How would I go about connecting to the main sewer - drill through the side?
- This will be for rainwater (i.e. surface run-off water), as well as grey water from a sink which will be inside the shed. Should I just aim the sink drain at the barrel in the ground?
- The barrel is perforated. Was that wise considering I want to potentially empty a sink into it? (I'm thinking surface pollution etc. if I'm washing an oily motorbike engine down )
