I presume I'll get a "Don't do it!" from ban_all_sheds, judging from his ID, but here goes...
I'm planning to run power to my workshop/shed, using 4mm2 Steel Wire Armoured (SWA) cable, and putting a small consumer unit in there, with an overall RCD, and MCBs for lights (6A) and sockets (16A). I'll take the power from a 20A MCB in the house CU.
Now the question I have is: I'll be earth-connecting the house end of the cable's armour, obviously, but should (may?) I also put in a ground stake and connect that to the shed's earth conductors? I realise this is mixing TN - C and TT, which isn't covered in the regs, but does it do any good? It seems to me that having a "real" earth that's connected to the ground near to the shed would give an extra level of safety in case of deteriorated earth conduction back to the house in the future.
Would the Part-P inspection fail due to the unusual earthing?
Incidentally, I was going to run this using an overhead catenary wire, but I've just seen that the regs want 3.5m clearance, and that would look daft, involving at least a 1m mast stuck up above the shed, so it looks like I'll be burying it. I presume the 3.5m spec would be part of the Part P inspection, since it is in the regs?
Cheers,
Howard
Cheers,
Howard
