Shed electrics, and a very 'first world' problem
11 Jan 2011
Oxford
I used one of the BG light switches and a 12W LED bulkhead from toolstation. The switch has an indicator:
full
You can wire it in a so-called 'locator' mode. Where the indicator goes on when the light's off.
full
It achieves this with neon wired across the connection, and it conducts just enough with the switch in the 'off' position to energise the light fitting:
full
And you guessed, it gives enough light to see the goddam switch in the first place, thus making the indicator redundant. Out of idle curiosity I measured the current, will cost me about 20p/year...
full
I fitted some LED's to a kitchen extractor hood and because the lights are controlled from a PCB as opposed to directly from a switch, they also gave a dim light. I suppose that the same leakage would have been present with the halogens they replaced, but in their case not enough to see any light from them.
