Good evening all,
I need some help with the inherited electrics in my shed.
The power comes into the shed into a double socket.This is connected to a light swith, which is used for a single flourescent light and a normal bulb light. Also from the double socket there is attached a single FCU utilised by a fridge/freezer. Finally, also from the double socket is a cable leading to another double socket and a single socket.
Is this set up safe? If not, what is the easiest way to sort it out, apart from getting in a qualified electrician? Will it require a further power cable from the house?
Many thanks.
Aldo's Dad.
Many thanks.
Aldo's Dad.
