My shed floor is rotting. The floor is built direct on the concrete slab. The roof doesn't project much beyond the walls or edge of the slab. It is below some trees and close to fences on two sides, so leaves build up against the side and are not easy to clear.
The shed ia built from wooden prefab panels. The floor is OSB on 2x2 joists. It's not great but I don't really want to rebuild the whole thing.
I want to raise the whole thing by jacking it up and place it on 100mm concrete blocks. Replace the floor joists with pressure treated wood and new boards.
Is that a good plan. How far apart can the blocks be? Should I place DPM between the blocks and the wood? Solid blocks or less dense ones? Any simple way to extend the roof
