Shed floor
22 May 2023
Hi all
I have had a shed delivered and installed but after a month I have noticed the floor bending between the bases joists so I was gonna use decking to put over the thin plywood flooring to make a really strong floor any advice as the decking has been ordered
Is it warping or softening due to damp?
What do the bearers stand on?
Have you got gutters and a downpipe to lead water away?
Hi ,
No it isn’t warping the flooring is to thin it sink’s between the bearers
What do the bearers stand on? Paving
No gutter’s
Gray
Are you saying your plan is to put decking over the top of the existing bowing shed floor? What is the spacing's of the existing floor 'joists'?
Yes to put decking over existing thin floor. The floor joists are12 inches apart
If you lay boards down, you will end up with a load of gaps, better to just lay down another sheet of osb or something
