I got a new shed installed and I was wondering about insulating it. Its your basic shed with 2x3 timber frame with cladding over it. I was wondering if I wanted to add insulation to the inside of the shed should I put a breathable membrane to the inside of the shed, stapled to the cladding from the inside and then wool in between the studs? Do I need insulation at all if I am using the shed as a workshop occasionally?
My plan is to put OSB boards inside the shed attached to the studs so that I can hang things too.
Any help would be greatly appreciated.
Cheers
Cheers
