shed insulation
9 Nov 2003
I am lining the interior of a shed and wish to apply insulation between the outer boards and the lining./ Two questions:
1. What insulation would anyone recommend that would fit within the 44mm depth of timber?
2. Should I apply vapour moisture paper between the outer boards and the insulation?
Thks
Use polyethylene sheets which is normally use for cold stoarge tank insulation and available from Wickes,then vapour moisture paper.
Many thks. Forgive my ignorance but are you saying the VPM goes between the insulation and the lining?
Shed panel > polyethylene sheets > vapour moisture paper
Polyethylene sheets in the middle.
I have a similar project. Situation is a timber shed with insulation similar to Celotex with an integral moisture vapour. The depth of the recess between timbers is approx 44mm the insulation is 25mm. Should the insulation be against the outer planks or brought forward to the front edge of the timbers, that is against the wall covering.
"forward to the front edge of the timbers" away from the outer panel
