Can anyone please tell me the best way to cut sheet insulation to fit between the rafters? the insulation is approx 100mm thick - and a large quantity is to be cut.
I actually use a meat cleaver and run it along an aluminium straight edge. It's got the depth to cut rockwool as well as polystyrene. I cut it before I take it up to the loft as you need to unroll the stuff on the floor first. Least amount of time spent in the loft the better anyway; awful job.
