I want to attach a high up shelf along a corridor, approx 2m across, into a brick wall. I'll likely use some 3/4" ply and 3 or 4 wall brackets. Ideally I'd like to have the brackets mounted internally so that they will be hidden when looking up. I'm always a little worried about mounting shelves this way though, as I presume the strength/holding power of the brackets isn't as good as it would be if they were routed outside, below the shelf?
Could some knowledgable people let me know if what I'm planning is safe enough? The weight the shelf will hold is uncertain, but it's intended as a storage type shelf, dvds, storage boxes etc. It's depth will be no more than 400mm. Any alternative fixing solutions, which still provide a clean appearance would be welcome too.
Any advice much appreciated.
