Shelf support pins smaller than 5mm
OM2
18 Jan 2007
I need to get shelf support pins for adding an extra shelf in a kitchen cabinet
The only ones I see are 5mm in diameter
The existing ones + ones holes are 0.3mm
Definitely 100% not 5mm
Where can I get these from?
What are they called?
0.3 mm my god they are small.
Hmm, maybe I got it wrong.
Just by eye balling, I would definitely day less than 5mm.
Set pic below:
From your picture I would say they are in fact bigger than 5mm diameter My guess would be more like 7 or 8mm.
Unless those shelves are about 30mm thick then those pegs ain't 7 or 8mm, kitchen shelves are normally 18mm, the OP needs to check with the drill bit method or pull one out and measure it, they look about 4mm to me.
