Hi all.
My 1st floor bedroom floor is wonky. Drops unto 40mm from edge to centre - looks like bowed joists. I'm loathe to sister each joists with new timber and someone suggested just shimming the joists - add a strip of wood to the top of each joist with varying thickness to create a level floor.
My concerns:
1) Is that an acceptable remedy?
2) Where would I get such long / thin strips of wood? I assume I would need various thickness as the joists will not all be bowed my the same amount?
These strips would need to be 7cm wide, unto 350cm long and between 1cm and 3cm thick.
Much appreciated in advance.
My concerns:
