shingle roof leak and hurricane questions
11 Oct 2013
Florida
United States
my roof leaks in several places. No one can find, not even the pros. I either need a complete new roof or a coating. Otherwise the roof looks fine. Two years ago, a 4 point inspection said it has 10 years life left. I did not tell them about the leaks. It was installed in 1994, so its not up to the latest hurricane standards. House built in 1952.
I have already installed rafter to block wall hurricane straps, secured the soffits, and gable end supports and used subfloor adhesive to attach the roof planks to the rafters and on the gable ends. Id like a new roof thats up to the latest hurricane standards, but a new roof is out of my budget. Im considering doing it myself, but i think its over my head. literally and figuratively.
I have several questions.
1-How well do those liquid roof coatings protect from leaking?
2-If I use a roof coating, can I secure the shingles to the planks with extra nails before I apply the coating?
3-What is the best material to fix spot leaks on a shingle roof? tar, silicone caulking, other?
4-I have tas100 approved ridge vents and suspect they are the source of some/all leaks. I did replace them myself on one of my ridges and noticed that the roofer who installed them with the last roof job (1994) did not follow manu instructions. When i replaced them, 2 leaks went away, two did not and now there is a third leak in that roof. The other two roofs have same ridge vents and one of those roofs leaks too. Since I still have leaks on the roof that i replaced the vents, i never replaced the other ones. Im considering finding a better quality ridge vent (but dont know how to asses), or I might just close up the openings and have no ridge vents. Suggestions/ideas?
5-Im also considering a metal roof. That i think i could install. Id need help from a qualified roofer and would find someone to help me. From what I have read, some metal roofs, like the metal shingles can last 50 to 100 years. I like that! Ive also read that some of the other metal roofs are not every strong against hurricanes. Your thoughts?
If I do #1 above, I will also replace or close off the ridge vents (#4 above).
Ive lived in this house since 1986 and plan on living here for the rest of my life, so i want a roof that lasts and that i dont have to worry about. Id like to feel sucure against hurricanes too. Im ok with yearly inspections and upkeep, especially if I can do it myself.
Every once in a while a plank to rafter 8d nail pokes up thru the shingles. Since 1986 I inspect yearly and seal up these holes. Which is why i asked about good shingle patching compound above. (#3)
thanks much for any advice. The rainy season is about over, so i need to get busy.
p
We don't use shingles much in the uk but I would guess if you used torch on felt then the wind would not be able to tear this off.
It sounds like you need to strip back to boards and start again. google sbs torch on roofing systems. I would not recommend coating over existing shingles.
that looks strong. I see flat roofs done that way. Im a medium pitch. I will do more research.
