Shingles leaking question..
6 Dec 2012
London
Hi guys, I would really appreciate some shingles help..
I have a traditional Edwardian London house where there is a leak above bay window on 1st floor. I digged in the angled attic above (roof conversion on 2nd floor with tiny space towards roof/wall). I found that the shingles-clad roof lays on sarking boards (no membrane) and that it seems to leak a little bit in at least 2 places. Still the distance from the actual leak in roof seems far to the spot in roof in below 1st floor; is that normal?
Also, if I try to fix myself should I just try to diy change a few shingles, or should I change all of them and put in underlay of some sorts? Also above where the bay window from the 1st floor there is a zink roof that seems to collect water towards inner edge; is that a problem per say? Thanks a bunch for any help! Rgds, Henrik
Re leak v drip placement, yea that's all to normal.
I wouldn't go to the extent of re-roofing and shingles have laid without a membrane for thousands of years (the Romans) Try fixing/replacing yourself, if you have the access and at the same time take stock of the general condition of the shingles (they should not look like new of course) for future planed works...pinenot
Are you talking about cedar wood shingles?
As a rule, i'd discourage DIY'ers from going on a pitched roof - if, indeed, you do have old cedar shingles, then they are possibly slimy and deadly underfoot.
A few pics of the roofs in question would really help. Plus a pic from below the "sarking boards"
Perhaps i misunderstand, but you seem to be talking about three separate roofs, a main roof, a bay roof, and a zinc roof - or have i got it wrong?
